Smart ACL
mcardell
Good morning,
Is there any bsmart access list feature that enable me to add and delete some statement from tha ACL without impacting all the other statements?
Any link on CCO.
sgjmgreve
The only way is to use a web tool like cms. Comes with most platforms.
On the CLI you have to remove and reenter the complete list.
Stefan.
mhussein
Level 4
Level 4
There is a new feature introduced as of IOS 12.2(15)T and 12.3(2)T releases:
IP Access List Entry Sequence Numbering
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122s/122snwft/release/122s14/fsaclseq.htm
Where you can assign sequence numbers to the ACL entries and reorder/add/remove lines by the sequence number.
Mustafa
