SMARTnet for 877
localgareth
I have a Cisco 877-K9-SEC, and I am playing around with the SSL VPN, very smart stuff!
I want to download the Cisco Remote Desktop tool, but I think I need a SMARTnet contract.
Which is the cheapest SMARTnet to buy? I dont want onsite maintenance / repair, just access to downloads :-)
Hope someone can help.
Gareth
Collin Clark
CON-SNT-CISC877A
SMARTNET 8X5XNBD ADSL Security Router
Should be about $50
HTH and please rate!
Thanks for the reply.
I cannot find that part number in stock at any UK supplier... is this part number current?
Is this any good?
CON-SW-PKG1-VS
mameiers
The easiest and most accurate way to find the correct maintenance for your product would be to contact either your local Cisco reseller or Cisco Partner.
