SNMP Trap problem!
mrunal_47
Level 4
Level 4
We have a primary DSL connection and a backup modem connection. As soon as primary fails, modem dials out. Under this situation we want backup interface (dialer) to send a trap regarding it own status with itself as source of the trap. Currently its not sending any traps regarding its own status. We cannot use "snmp-server source-interface" in the configuration because of some limitations. Any experts here?
ariesc_33
Level 4
Level 4
hi! what ios and router model?
on the dialer interface, check if this command is available
snmp-server enable traps snmp linkup linkdown
The router will send a trap once the link status changed.
http://www.cisco.com/en/US/partner/docs/routers/7300/technical_references/7301_mib_guides/7301_mib_specs_guide_v3/7301mib4.html
BR,
Aries
The problem is that the dialer interface does not send a trap regadring its own status, but it does send the subsequent traps!
