SNMPv2 and v3
Hi need help to configure SNMP in cisco switch 550x 48 ,switch ip is 192.168.132.4 and probe ip 172.10.16.8  , can anyon share configuration for this. is ACL need to configure for port 161 for snmp.?
More detail I need the snmp have a lot of options.
Also your post title is snmpv2 or v3 which one you want to use?
Snmpv2 is easy config
Snmpv3 is more secure
MHM
can you please share both version configuration if possible ?
balaji.bandi
There is a good example how you can configure with ACL - any issue post with configuration what is not working.
https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/20370-snmpsecurity-20370.html
BB
