Software Bug Toolkit problems
darenira1981
Community Member
I try to find bugs associated with the equipment C6506-E but unfortunately can not find anything related to the tool:
I've been trying to change the number of release according to the picture below (12.2SXJ, 12.2.33-SXJ,
12.2.33-SXJ1 to 12.2.33-SXJ6), but I get no results
This is the image I'm looking for:
ADVANCED IP SERVICES SSH
s72033-advipservicesk9_wan-mz.122-33.SXJ6.bin
I would greatly appreciate your prompt help.
Regards.
Wilson Bonilla
Level 8
Level 8
What if you just type in the image name, searching based on release, serial # or anything doesn't work for me either...
Regards.
Wilson B.
Hi all,
I' ve sent a e-mail to Cisco where I tell them about this problem with the new "Bug Toolkit" tool.
For the moment, I recommend you to use the old Bug Search tool because the new tool is on beta yet.
Regards.
Hi Iker,
Can you share with us what is the cisco feedback on this?
