06-22-2018 08:14 AM - edited 03-08-2019 03:27 PM
Hello all,
It looks like the QoS service-policy (shape) on the vlan interface is only limiting download, but not upload. That is a huge issue for us, since sometimes we can't segregate the port for the client from the other clients. So I only need to be able to limit the traffic, not to prioritize it.
Thanks.
Solved! Go to Solution.
06-23-2018 06:06 AM
06-25-2018 06:28 AM
06-22-2018 12:22 PM
06-22-2018 01:27 PM
Hi Eric,
Thanks for the reply. For the sake of the simplicity, let's say the customer's router is connected directly to one of the switch ports. We create an SVI interface and put the port (where the client is connected) to access mode. And we want to limit the traffic to 100/100M. How would that policy look like?
Thanks in advance.
06-23-2018 06:06 AM
06-23-2018 12:25 PM
Hello Joseph,
Thank you very much. We mainly use 7600 and 6500 series, so I dont think there should be issues. Ill try this on Monday and I'll let you know if it's working.
06-25-2018 12:48 AM
Hello Joseph,
I was not in front of my PC when you've sent me your response. Basically this is exactly the same as I already did. But it's only affecting the download, upload is unshaped. I have set the 30M policy on SVI (going through 100M port).
This is the result:
Any advice?
06-25-2018 04:04 AM
06-25-2018 04:51 AM
Hello Joseph,
How can I check that?
We use this SUPs on our 6500:
Supervisor Engine 720 10GE - VS-S720-10G SAL12362KA1
We use these SUPs on our 7600:
Route Switch Processor 720 10GE - RSP720-3CXL-10GE
6 5 Route Switch Processor 720 10GE - RSP720-3CXL-10GE
06-25-2018 06:28 AM
06-25-2018 07:31 AM
Hello Eric,
It looks it was really the mls qos vlan-based command!!! I've applied it to the physical interface and it looks like it's shaping it now.
Thank you very much, both of you.
