08-15-2016 11:39 AM - edited 03-08-2019 07:00 AM
Dear fellow cisco users,
we have 2 cisco SG550XG and we would like to stack them over an LAG of 4 physical ports on each side.
According to the product data sheet this is possible and supported:
High-speed stack interconnects |
Cost-effective high-speed 10G fiber and copper interfaces. Support LAG as stacking interconnects for even higher bandwidth. |
Unfortunately I am not able to configure it properly.
When I setup the stack vie the web frontend, I can only select physical ports. I did this, but it seems as if there is only 1x 10G used.
The CLI command show stack links gives:
Topology is Chain
Unit Id Active Links Neighbor Links Operational Down/Standby
Link Speed Links
1 te1/0/19-22 te2/0/19-22 10G
2 te2/0/19-22 te1/0/19-22 10G
CLI command show stack configuration gives:
Unit Id After Reboot Configuration
Unit Id Stack Links
1 Auto te19-22
2 Auto te19-22
Also when creating the stack via CLI config stack configuration links te 19-22
it does not give different results.
I've also created lags on both switches before stacking, but that does not make a difference.
I can not use the lag as stack port via CLI "stack configuration links lag 2"
I am stuck now.
I would really appreciate any help!
Thanks in advance,
Thomas
08-16-2016 04:39 AM
Thanks to chat support: the answer is too easy:
when you create a stack and add multiple connections / links / cables, the stack will automatically use them in parallel (if they are active).
You can check the link status via cli:
show stack links detail
Result:
Topology is Chain
UNIT ID Link Status Speed Neighbor Neighbor Neighbor
Unit ID Link MAC Address
1 te19 Active 10G 2 te19 00:8e:73:c3:b2:94
1 te20 Active 10G 2 te20 00:8e:73:c3:b2:94
1 te21 Active 10G 2 te21 00:8e:73:c3:b2:94
1 te22 Active 10G 2 te22 00:8e:73:c3:b2:94
2 te19 Active 10G 1 te19 00:8e:73:c1:b3:2c
2 te20 Active 10G 1 te20 00:8e:73:c1:b3:2c
2 te21 Active 10G 1 te21 00:8e:73:c1:b3:2c
2 te22 Active 10G 1 te22 00:8e:73:c1:b3:2c
