Solved network
alohakibok
Thanks for your help
5 Replies 5
post the (zipped) project (.pkt) file...
This is a homework from your school? Wouldn't it be better for your learning success if you show us your solution, describe your technical problems and then you get feedback on it?
Martin L
Just connect Server and PCs to layer 2 switch. by default they all should be in vlan 1. server has DHCP tab where you can enable DHCP service and set up IP range of 172.16.x.x. make Router Cisco as default gateway for your network 172.16.x.x. network.
Cisco Learning network is a place for such exam studying topics ,see https://learningnetwork.cisco.com/content?filterID=all~objecttype~objecttype%5Bthread%5D&itemView=detail
Leo Laohoo
I am with Karsten on this.
This looks like school work.
Kindly go and have a chat with the instructor because the answers we will provide will not necessarily be what the instructor is looking for.
alohakibok
Ok
