Some Commands Not Accepting w r t WCCP Configuration on 3750G switch
 I am trying to configure WCCP on Cisco3750G-48PS switches. But one of the Cisco command " ip wccp 53 redirect in" is not accepting on Gig interface. I have tried it by uploading latest IOS image and also tried with different featuresets.
Can someone help me if it can be achieved.
MAC
Regards MAC
6 Replies 6
Reza Sharifi
What is the error message when you enter the command?
What is the output of "ip wccp 53 redirect ?" ?
Also, what is your license level? "sh license"
I am configuring the below commands
interface GigabitEthernet 1/0/47
It says
Switch(config)#interface Vlan11
Switch(config)#ip wccp redirect exclude in
% Invalid input detected at '^' marker.
Switch(config-if)#ip wccp 53 redirect in
% Invalid access list name.
MAC
Regards MAC
What is your license level?
Can you provide  sh license and sh version?
Hi Reza,
As requested i have Attached show version and show license in notepad. The command show license is not accepting
MAC
Regards MAC
Your version should support WCCP.  Also, you have the correct license/image.
Can you try following this document and config WCCP?
This is for 12.2(55), but should also work for your version.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_55_se/configuration/guide/scg3750/swwccp.html
Thanks for your input, so ip wccp redirect in command doesn't support in 3750 switches and instead we have configure it as web cache service and use the command ip wccp web-cache redirect in right?
MAC
Regards MAC
