SPAN 2960
Rohmat Tri Indra
Community Member
After configuring SPAN on 2960, IDS can't connect to anything, IDS & PC client same switch on 2960
Please correct the below configuration.
interface GigabitEthernet0/1
description " To L3 3750"
switchport mode trunk
interface GigabitEthernet0/11
description "PC client"
switchport access vlan 8
description " To IDS"
monitor session 1 source interface Gi0/2
monitor session 1 destination interface Gi0/3
Switch#sh monitor
Session 1
Type                        : Local Session
Source Ports            :
Both                        : Gi0/2
Destination Ports      : Gi0/3
Encapsulation          : Native
Ingress                    : Disabled
Karthick Murugan
check the output rate on the destination interface. 2960 uses shared buffer. Make sure the span is not overwhelming the buffer available.
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
Hi All,
Is there supported document that said about buffer/cpu consumption at Cat-2960 during running SPAN monitor ?
Rakhmad
