SPAN configuration for a specific protocol
stam_heshbon
Community Member
The routers we are using are Cisco 6500's with 720-3BXL Sup engines.
I have a network in which I'd like to watch only a specific protocol, in this example SMTP traffic. I'd like to see all traffic going to and from port 25 (to monitor all outgoing email regardless of who the MTA is, so it is not fropm a specific known IP address).
Since most the traffic on the network is not related to the protocol I am looking to follow/monitor it'd be useful to set the SPAN to only provide me with traffic destined to port 25 (which would be 2-3% of total traffic).
How do I go about configuring the Router?
Sam
Jon Marshall
Sam
As far as i am aware you cannot do this because SPAN does not actually look into the packets, it merely sends a copy of the packet to a destination port.
If you want to monitor only smtp traffic then you would be better off looking at Netflow rather than SPAN. However if you need to see inside the actual packets you will have to use SPAN and send all traffic and then analyse with a protocol analyser such as wireshark. Wireshark will allow you to set filtes based on TCP/UDP ports so it would only show you what you wanted to see.
Jon
Thanks.
If I am already going to through at this massive amounts of HW I might as well look into the right thing. What would you recomend as the "port mirroring" technology of choice to get a copy of SMTP. As it is a fraction of the general traffic it seems wrong to try SPAN and filter it on a huge server. I'd expect a network device could forward a copy of a specific pattern with ease, but which would it be?
stam_heshbon wrote:
Thanks.
Stam
Sorry, i completely forgot about the use of VACLs to capture specific traffic. Have a look at this link and see if it helps -
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080883ca2.shtml
Once again, apologies for that.
Jon
Thanks, looks like it could do the trick. I'll have a try.
