04-19-2017 01:59 AM - edited 03-08-2019 10:14 AM
SPAN from 10G WAN link with little traffic to 1G interface. Will it work ?
Solved! Go to Solution.
04-19-2017 02:23 AM
what platform/model is this on ?
if its nx-os you can rate limit your span , either way once your traffic is under a GB you should be fine , you don't want to overload the interface
By configuring a rate limit for SPAN traffic to 1Gbps across the entire monitor session, you can avoid impacting the monitored production traffic.
1. switch# configure terminal
2. switch(config)# interface ethernet slot/port
3. switch(config-if)# switchport monitor rate-limit 1G
4. switch(config-if)# exit
04-19-2017 02:27 AM
Hi that's fine with that kind of volume of span to a GB port you shouldn't face any issues
04-19-2017 02:23 AM
04-19-2017 02:25 AM
Its a Cisco 6509-E. I want to install an IDS server and mirror the in/out traffic to it. Since the traffic does not exceed 200-300MBs I do not want to use the last 10G interface as the destination of the SPAN.
04-19-2017 02:27 AM
04-19-2017 02:48 AM
Thanks for the reply.
I have one more question regarding SPAN. My main focus is to detect spams and viruses on the Employee VLAN.(We have server,student,guest and print VLANs too)
Would that traffic be detectable with my SPAN config stated above or should I use only the Employee VLAN int. as the source of the SPAN ?
Lets put it this way, Im confused about the basic concept of how the traffic looks like when it leaves a vlan and routed out to the internet.
04-19-2017 03:55 AM
That depends on your IDS system it should see something
So we span everything for security reasons but we use certain devices/hardware and software for different tasks
We use a bluecoat to detect any issues going outbound to the web for protection
We use DLPs to review SPAN traffic and other software that can inspect individual SPAN packets, the thing with security is there is no one fix all product , you need to use layers of devices that specialise in certain functions , especially when trying to track viruses but IDS is a very good start
SNORT is an open source tool which is very good at tracking viruses too
having host level scanners inbuilt to your machines will also help especially when capturing that data
if the IDS can take it I would collect as much traffic as possible from each vlan , don't think printer vlan would be required really but student and guest I would capture too
