span port configuration to listen to specific traffic only
donnie
Hi all,
Is it possible to configure the span(switch port analyzer) port and restrict it to only listen to ingress and egress of TCP/1433 from the source port?
Pls advise, thks in advance.
terrencepayet
Hi don li,
I dont think you'll be able to to use SPAN to listen on specific port. but you can use VACL, but that will depend on the model of your switch.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml
HTH.
Terence
cadet alain
you'll have to configure a capture filter on your packet analysis software.
Regards.
Alain.
