Spanning-Tree Issue on Traffic Network Ring 6 IE-4000
JTS-Wireless
I have created a post a over a week ago having issues seeing access points from the main switches on a traffic network ring. That issue has been fixed, seeing that it was a a routing issue, but now, a spanning-tree issue has cropped up instead. Currently, the state of the interfaces need to be forwarding, but generally, at least 1 port on each site is being blocked, and though some sites get all the ports the access points connecting to are all in the forwarding state, this changes every few hours at each site.
The network is on Spanning-tree mode rapid pvst.
I have added the network topology as well as the the port configurations, spanning-tree configuration and output for the show spanning-tree command for the management VLAN.
My main issue as stated previously is that I need the ports to all be forwarding, but these ports are all trunk ports.
Node A# show spanning-tree vlan 5
VLAN0005
Spanning tree enabled protocol rstp
Root ID Priority 8197
Address 3473.2d3d.6180
Cost 3
Port 96 (Port-channel5)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 8197 (priority 8192 sys-id-ext 5)
Address 3473.2d3d.6200
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Gi1/1 Desg FWD 4 128.1 P2p
Gi1/2 Desg BLK 19 128.2 P2p Dispute
Gi1/3 Desg FWD 19 128.3 P2p
Gi1/4 Desg FWD 4 128.4 P2p
Po1 Desg FWD 3 128.64 P2p
Po5 Root FWD 3 128.96 P2p
Node A Port Configurations
spanning-tree mode rapid-pvst
spanning-tree vlan 1-4093 priority 8192
interface Port-channel1
switchport trunk native vlan 1110
switchport mode trunk
interface Port-channel5
switchport trunk native vlan 1120
interface GigabitEthernet1/1
description AP 1
interface GigabitEthernet1/2
description AP 2
interface GigabitEthernet1/3
description AP 3
interface GigabitEthernet1/4
description AP 4
interface GigabitEthernet1/5
channel-group 1 mode active
interface GigabitEthernet1/6
channel-group 5 mode active
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/9
description UPLINk2AP
interface GigabitEthernet1/10
port-type eni
interface GigabitEthernet1/11
description UPlink2LAN
port-type eni
interface GigabitEthernet1/12
description T-ShootPort
port-type eni
switchport access vlan 5
switchport mode access
interface Vlan1
no ip address
shutdown
interface Vlan5
description MGMT
ip address x.x.x.x 255.255.255.0
Node B# show spanning-tree vlan 5
VLAN0005
Cost 7
Port 64 (Port-channel1)
Address 806a.0003.5300
Aging Time 300 sec
Gi1/13 Desg FWD 4 128.13 P2p
Gi1/14 Desg FWD 4 128.14 P2p
Po1 Root FWD 3 128.64 P2p
Po2 Altn BLK 3 128.72 P2p
Node B Port Configurations
description PTP_OSPF_Link_Node A
interface Port-channel2
description PTP_OSPF_Link_Node E
switchport trunk native vlan 1150
description UNUSED
shutdown
description UNUSED
shutdown
description UNUSED
shutdown
description UNUSED
shutdown
channel-group 2 mode active
description PTP_OSPF_Link_Midway_Pump_Station
no switchport
ip address x.x.x.x  255.255.255.248
description Firewall
no switchport
description Uplink to Traffic Server
port-type eni
switchport access vlan 7
interface GigabitEthernet1/13
description AP 1
interface GigabitEthernet1/14
description AP 2
interface GigabitEthernet1/15
interface GigabitEthernet1/16
port-type uni
interface GigabitEthernet1/17
interface GigabitEthernet1/18
interface GigabitEthernet1/19
interface GigabitEthernet1/20
interface Vlan1
no ip address
shutdown
interface Vlan5
--More--
description MGMT
Node C#show spanning-tree vlan 5
VLAN0005
This bridge is the root
Aging Time 300 sec
Gi1/1 Desg BLK 4 128.1 P2p Dispute
Gi1/2 Desg FWD 4 128.2 P2p
Gi1/3 Desg FWD 4 128.3 P2p
Gi1/4 Desg FWD 19 128.4 P2p
Po4 Desg FWD 3 128.88 P2p
Po5 Desg FWD 3 128.96 P2p
Node C Port Configurations
interface Port-channel4
switchport trunk native vlan 1130
description AP 1
description AP 2
description AP 3
description AP 4
channel-group 4 mode active
port-type eni
interface Vlan1
no ip address
shutdown
interface Vlan5
description MGMT
Node D# show spanning-tree vlan 5
VLAN0005
Cost 3
Port 80 (Port-channel3)
Bridge ID Priority 32773 (priority 32768 sys-id-ext 5)
Address 3473.2d74.f600
Aging Time 300 sec
Gi1/2 Desg FWD 19 128.2 P2p
Po3 Root FWD 3 128.80 P2p
Node D Port Configurations
interface Port-channel3
switchport trunk native vlan 1140
description AP 1
description AP 2
description AP 3
shutdown
description AP 4
shutdown
channel-group 3 mode active
switchport m
Mode trunk
port-type uni
port-type uni
interface Vlan1
no ip address
shutdown
interface Vlan5
description MGMT
Node E#show spanning-tree vlan 5
VLAN0005
Cost 6
Address 4c5d.3cb6.2a00
Aging Time 300 sec
Gi1/2 Desg BLK 4 128.2 P2p Dispute
Po2 Desg FWD 3 128.72 P2p
Node E Port Configurations
description PTP_OSPF_Link_Node B
description AP 1
description AP 2
description AP 3
description AP 4
port-type uni
port-type uni
port-type uni
interface Vlan1
no ip address
shutdown
interface Vlan5
description MGMT
All port FWD that impossible for your design,
ONE trunk must be BLK to broke the L2 LOOP
but
since you run Rapid-PVST then you can do Spanning tree load balance when the VLANX in trunk Z is FWD but VLANY is BLK.
this need to make two switch as Spanning tree Root, one root for each VLAN.
Jitendra Kumar
