Spanning-tree issue
darren-carr
Level 2
Level 2
Hi Guys
I have got a weird issue. A switch I have nominated does not appear to be forwarding for a particular vlan over a trunk (please see below).
Port Mode
Encapsulation Status Native vlan
Gi0/46 on 802.1q trunking 1
Gi0/48 on 802.1q trunking 1
Po1 on 802.1q trunking 1
Po2 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/46 1,31
Gi0/48 1-4094
Po1 1-4094
Po2 1-4094
Port Vlans allowed and active in management domain
Gi0/46 1,31
Gi0/48 1,30-31,71,73
Po1 1,30-31,71,73
Po2 1,30-31,71,73
Port Vlans in spanning tree forwarding state and not pruned
Gi0/46 1,31
<strong>Po1 1</strong> (issue is here not forwarding VLAN31)
Po2 1,30-31,71,73
The switch is connected to another switch using a 3Gbps etherchannel... but for some reason does not want to forward this vlan. It is causing another issue as a different interface on both switches then goes off to two other switches and certain devices attached to these cannot communicate (all on VLAN31). I think this is causing the issue but am not sure how to fix it.
I have checked the trunk links and the vlans allowed, etc but cannot see anything obvious?
Any ideas? Thanks
andrew.prince
Level 10
Level 10
post the output of "show span vlan 31" on the switch that is having the issue
andrew.prince
Level 10
Level 10
glen.grant
If this is a transparent setup make sure the layer 2 vlan for vlan 31 is created on each switch . Verify on each switch with the show vlan command and make sure vlan 31 shows active.
Guys
I shut down the portchannel between the two switches, re-enabled and the VLAN is now being forwarded over the switch.
Not sure why it stopped or if something caused a STP reconvergence or something...anyway.. all is good now... thanks for you input
Darren
