Speed between Switches & IDF MDF
springxdxml
I had a question reguarding the types of speed and cable one should use when connecting switches in an IDF togeather, and then connecting those swtiches back to an MDF.
If I connect each switch in the idf togeather with gigabit ethernet, probably cat 6 cables,  how do I know that these 1 gigabit inter-connections will support all the traffic between the switches without issues? What if the right speed that I should have used was 10 gigabit? How often is 10gigabit used to interconnect switches in the idf?
And this is the same issue im trying to figure out with connecting the IDF back to the MDF. Would 1 cat6 via gigabit ethernet speed be enough for all that traffic goign back to the MDF? Is there a general rule or something to follow so that I know what speeds to use when?
Also, why use fiber 1gb vs 1gb over cat6 if distance between mdf and idf is less than 100m.
Thank you for your time
Leo Laohoo
Duplicate post #1
