02-10-2016 03:20 AM - edited 03-08-2019 04:32 AM
We have a cisco 2611 router for which I was trying to set the speed/duplex to 100/full, I am able to execute command as full-duplex over the interface Ethernet0/1 but could not set the speed to 100 as the command speed itselves is not able to get recognized by the router over the interface.
Also the speed/duplex is not visible when checked in the output "show int Ethernet0/1".. Need to know how much speed that this interface support.. kindly advise..
#show int Ethernet0/1
Ethernet0/1 is up, line protocol is up
Hardware is AmdP2, address is 0009.4312.a941 (bia 0009.4312.a941)
Internet address is 10.49.50.82/30
MTU 1500 bytes, BW 1024 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:27:36
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
30 second input rate 0 bits/sec, 1 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
1713 packets input, 126981 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
585 packets output, 42644 bytes, 0 underruns
0 lost carrier, 0 no carrier
#show run int Ethernet0/1
Building configuration...
Current configuration:
bandwidth 1024
ip address 10.49.50.82 255.255.255.252
no ip redirects
no ip unreachables
no ip directed-broadcast
no ip proxy-arp
no ip mroute-cache
load-interval 30
full-duplex
no fair-queue
no cdp enable
end
cisco 2611 (MPC860) processor (revision 0x00) with 26624K/6144K bytes of memory.
Processor board ID JAD060908QX (3077235151)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
2 Ethernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
02-10-2016 04:35 AM
Hi its 10mb port only its not a fastethernet port so it wont accept speed 100 try speed 10 as standard Ethernet , old router
02-10-2016 08:04 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Mark has noted, an (original) Ethernet interface only supports 10 Mbps.
BTW, full-duplex was "added" later to 10 Mbps Ethernet, so you can run into issues using it.
02-10-2016 11:58 PM
Thank you Joseph and Mark for the clarification..
