Splash Access on switch level
Alexs20
Level 2
Level 2
Is it possible to activate and configure Splash pages on Switch level (based on VLANS)?
So any device that connects to the network via wire will see the captive portal
ww^
Meraki Community All-Star
As @jdb1 correctly mentioned, not natively. But if you have the strict business requirement to do this, you could achieve this with the Cisco ISE. But if you have a RADIUS server like the ISE, implementing 802.1X is always the better option.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
