split multilink trunks
carl_townshend
Hi all, I know cisco dont do this yet, but I believe that its a feature of nortel, I have seen I diagram where they have an access switch connected to 2 distribution switches via smlt, this is where the access switch has the 2 connections binded to form 1 but then its split into the dist switches, but on the diagram I have seen, it says only one of the links is active on one of the distribution switches, how have then done this, i believe that spanning tree is turned off also.
0 Replies 0
