SPT Question
dcanady55
Level 3
Level 3
I have the following setup and everything is working fine.
3 HP switches in Suite A each with an uplink to the core another HP switch, 3 HP switches in Suite B each with an uplink to the core. The 3 switches in each suite are not interconnected to each other and they don't have SPT turned on. The core switch is the only one with STP turned on.
I am replacing the Core with a new Cisco 3560 and taking the old HP core and demoting it to just a user switch. My question is should I turn off STP on the old core and have one instance of STP just on the new core or should I turn on STP on all of the switches?
Thanks for any feed back.
I hope you are talking about Spanning tree protocol.
It is simple rule - Never turn off spannning tree protocol. It always saves !!!!
Hope this helps.
Please always rate all helpful posts
