sr2024 replacement
Heron
Our SR2024 v3 switch is finally dying and is no longer supported.
Does anyone know if there is a direct replacement?
Thanks!
Heron
9300 series looks good but too pricey and more than we need for this particular application.
We found the 112 series small biz switches that look promising:
 https://www.cisco.com/c/en/us/products/switches/110-series-unmanaged-switches/index.html
And from the competition, Netgear makes some similar products like the JGS524.
Cheers.
If all you need is a simple switch, a Nethear device should do it. Usually, Cisco is much more expensive than Netgear, but if all you need is just a simple layer-2 device, the Netgear should be sufficient.
