SRM or NSF
davidcruise
i have router 7606 ,with 2 supervisor engines ( 720 ) ,
i configured sso redundancy as follows:
redundancy
mode sso
main-cpu
auto-sync running-config
so how can i verify that the working mode is NSF or SRM?
lamav
Level 8
Level 8
Hi:
What version of code are you running?
After 12.2(18)SXF, SRM is not an option and NSF is automatically enabled.
Victor
iam using s72033-advipservicesk9_wan-mz.122-18.SXF11.bin
Hi, David:
12.2(18) SXF11 does not support SRM with sso. The default is NSF. SRM is not supported for any software version later than 12.2(18)SXD
To verify that the NSF feature exists, you can query the switch under the roouter configuration mode prompt.
Example:
Router# config t
Router(config)# router ospf 2004
Router(config-router)# ?
Then look for the the NSF option.
Also, take note that CEF NSF is enabled by default once SSO is configured.
Please rate my post if it helped you.
Victor
