srr-queue bandwidth command understanding
szebula51
Trying to understand the actions caused by the srr-queue bandwidth commands.
I have a fast ethernet interface with the following
srr-queue bandwidth share 2 90 5 3
srr-queue bandwidth shape 0 2 0 0
srr-queue bandwidth limit 13
So what do they all use to calculate their values with? Do the all go to the physical interface, 100 meg in this case or do they have impact on one another? That is does the limit 13 impact the values calculated via the share and shape, or visa versa, or neither (all use 100 meg)?
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Have you read the corresponding configuration guide and Cisco white papers and/or tech notes on these commands?  For example, http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_52_se/configuration/guide/swqos.html and http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a0080883f9e.shtml#topic3
If not, suggest you start with (like) those as they should answer your questions.
If you still have questions, post again to this thread or start a new one.
