ssh from outside problem
jigsaw2026
I cannot ssh to my router (878) from outside. I have an access-list on the outside vlan and I can see that it is being hit on the ssh entry, but it just times out. I can ssh from inside no problem.
Any ideas what could be wrong. I have PAT/interface overload for the IP address, but I don't see why that would be a problem as I commonly use this setup.
Any ideas would be very much appreciated.
J
i-kendall
Try removing the access list temporarily, to prove if it is the cause. I assume you do not have access-list applied to the vty interfaces (access-class) - just checking the obvious :-)
Other than that I think we need to see the config to diagnose this further.
Iain
