stac switching
olly ahmed
Can anyone describe me what is stack switching & how it is performed ? Is there separate model for stack switch ? How to manage stack switches individually ? Can anyone share the details about stack switching from cisco.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Generally, stack switching is software that makes multiple devices behave as if it was one device.  Often special ports are used, which may be optional equipment.
Cisco support stack switching for the 3850, 3650 and the earlier 3750 series.  They also support stack switching in the 2960S and 2960X series.
VSS, found on some 6500s, 6800s and 4500s, might be considered very similar to stack switch.  However, VSS uses ordinary ports and is limited to just two member devices.
