Stack Compatibility Between CISCO 3750X AND CISCO 3750G
Hi Friends
We Have an exsisting stack switch, with 3750G . i Need to add new 12 Port SFP switch to the exsisting stack.
Exsisting stack switch  software and ios Image is psted below
Switch Ports Model              SW Version            SW Image
*    1 12    WS-C3750G-12S      12.2(52)SE            C3750-IPSERVICESK9-M
     2 28    WS-C3750G-24TS-1U  12.2(52)SE            C3750-IPSERVICESK9-M
     3 28    WS-C3750G-24TS-1U  12.2(52)SE            C3750-IPSERVICESK9-M
     4 28    WS-C3750G-24TS-1U  12.2(52)SE            C3750-IPSERVICESK9-M
My New SFP Switch is 3750X-12 ports switch, i tried upgrading the new SFP Switch with the same image as in master.
But after upgrading when i boot from the upgraded image i am getting an  below error
Error:hardware not supported by firmware
        Try loading newer software instead
         System resetting....
My Doubts
Whether this Hardwares are compatible to add (Cisco 3750X & Cisco 3750G)
what is the least Ios requirement i needed in Cisco 3750X to add it to 3750G stack
I seen several forums telling that we need atleast 12.2(58) ios  and few stating 12.2(53) ios. Please confirm the correct hardware and software requirement
Thanks for youe help in Advance
Guys.
Safwan
2 Accepted Solutions
Marvin Rhoads
You have to have at least 12.2(53) to support the 3750X hardware. Reference.
12.2(55)SE8 would be recommended based on general stability and bug fixes.
Marvin's post is worth it's weight in gold and doesn't deserve a "4" rating.
Alos these 3750G Stack is a core .. (Different buildings connects from here). So its required Layesr 3 capabailites
Could you tell me to run the stack with layser 3 capapbailities, whats the IOS train i need to use on Both switches?
Make sure your 3750X is running the same feature set as the rest of the stack, i.  e.  IP Services.
18 Replies 18
Marvin Rhoads
Thanks marvin..
for you rprompt response
its very useful.
So To Connect the 3750X  to 3750G stack i need minimum 12.2(53)
Excluding this we have any other pre requsities??
Hello Safwan.
12.2(53) might be available for some 3750x and not for other in the cisco support website... so I would say:
1- Currently at least you will need to have 12.2(55).
2- For 3750x platform note that all iOS images are either universal or ip base.
3- For 3750G platform note that all iOS images are either ip base or ip services.
Having said that, you will need to run at least 12.2(55) train in both 3750G and 3750X switches. If you need layer 3 capabilities chose universal for 3760x and ipservices for 3750G.
Regards.
Wilson B.
Hi Wilson,
Thankd for your Reply
Yes..
Currently the 3750G Stack having ipservice image(C3750-IPSERVICESK9-M) and new 3750X has universal image(
c3750e-universalk9-mz.122-58.SE2)
when i try to downrage the 3750X to (C3750-IPSERVICESK9-M) it throwed me an hardware error
So to get this working
1) i need to upgrade my current exsisting stack to 12.2(55) currently its running 12.2(52)
2)downgrade the new cisco 3750X to ios version 12.2(55)
Reagdrs
SAfwan
Leo,
Thanks for your Response.
For running Layer 3 we dont require any special ios??
So in a nutshell
current IOS
Old 3750G Stack:12.2(52)SE -C3750-IPSERVICESK9-M
New 3750X STACK:3750e-universalk9-mz.122-58.SE2
1)  if i use 12.2(58) -  c3750-ipservicesk9-mz.122-55.SE8.bin same ios in both 3750G & 3750X Switch , it will work as stack ?
Thanks to confirm
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
To run IP Services on the 3750X, you'll need the universal image AND an IP Service feature license.  (The license is something "new" to the -E/-X 3750, i.e. not found on your 3750Gs.)
It's possible to run different feature sets within a 3750 stack, but not sure if there's any special requirements for a mixed stack (i.e. original series 3750s and the later -E/-X series).
PS:
Also BTW, mixed 3750 stacks "take away" some of the advantages of the -E/-X 3750 stacks.
You will not be able to get the 3750X to boot up or load this filename because it's designed for 3750G.
As what Joseph has stated, 3750X needs to run the "universal" plus you need to ensure the 3750X has the "IP Services" license installed.  Use the command "sh license" to verify on the 375X.
Hi Leo,
Thanks for your Info..
Please find the show licensce output from the New  switch 3750X switch. Will it has the required licence?
Switch#sh license
Index 1 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 2 Feature: ipbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
Bcoz when i gave the same command in Core switch (3750G-12 port ) it is showing as
% License not supported on this device
So currently if i use 12.2.55-SE5 Software version in all switches and use
below IOS image in
WS-C3750X-12S : c3750e-universalk9-mz.122-55.SE5.bin
and below image in
WS-C3750G-12S : c3750-ipservicesk9-mz.122-55.SE5.bin
can i stack it sucessfully or am i missing smoenthing??
Disclaimer
Posting
Switch#sh license
Yes and no.  You're running an evaluation license for IP Services, which means you have the right license but it will expire in 8 weeks and 4 days (then it will be just IP Base).
As I noted in my earlier post, original series 3750s don't support hardware licensing.  Legally you need "paper" licenses.  Technically, feature set depends on installed image (and yours shows IP Services).
below IOS image in
and below image in
You should be able to stack them, but again, you're 3750X's IP Service license will expire.
Hi Joesph
Thanks for your Replies.
Correct me if i am wrong
1) This stack option will work, But since we have an Evalautation licence it will stop working after 8 weeks? If so, what i need to do get the permanenet licsense?
2) 3750G's doesnt support Hardware licsensing, But since feature set depends on the Ios image, And we are running an ip services image set, Which is required for this stack Connectivity, So this hardware liscensing for 3750G wont be an problem correct?
Please add , if i missed something
Safwan
Disclaimer
Posting
Yes, evaluation license will stop after 8 weeks.  You can purchase a licenses for IP Services.
IP Services isn't required for stacking, but I don't know if original series running IP Services will work with -X with IP Base.
Once you add the switch with evaluation licence it will work. But if you have any ipservices features command in the Master switch running it will only be supported till 8 weeks and 4 days with this in stack.After that this switch will be no more in stack.
Guys,
I Tried to Simulate the Stacking, with the spair 3750G Switch with the new 3750X. i am Successfuly able to stack it.
Switch#Sh SwItch
Switch/Stack Mac Address : 10f3.119e.d280
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 10f3.119e.d280     5      1       Ready
2       Member 3cdf.1e59.2780     1      0       Ready
Switch#sh vers
Switch#sh version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE, RELEASE SOFTWARE (fc1)
Switch uptime is 3 hours, 49 minutes
System image file is "flash:c3750e-universalk9-mz.122-55.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
Next reload license Level: ipbase
cisco WS-C3750X-12S (PowerPC405) processor (revision A0) with 524288K bytes of memory.
Processor board ID FDO1707Z0CG
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
44 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 10:F3:11:9E:D2:80
Motherboard assembly number     : 73-13329-04
Motherboard serial number       : FDO17061NB8
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3750X-12S-S
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO17340ZPC
System serial number            : FDO1707Z0CG
Top Assembly Part Number        : 800-35090-04
Top Assembly Revision Number    : B0
Version ID                      : V03
CLEI Code Number                : CMMFG00ARC
Hardware Board Revision Number  : 0x04
*    1 18    WS-C3750X-12S      12.2(55)SE5           C3750E-UNIVERSALK9-M
     2 28    WS-C3750G-24TS-1U  12.2(55)SE5           C3750-IPSERVICESK9-M
Switch 02
Switch Uptime                   : 3 hours, 43 minutes
Base ethernet MAC Address       : 3C:DF:1E:59:27:80
Motherboard assembly number     : 73-10219-07
Power supply part number        : 341-0098-02
Motherboard serial number       : FOC13441NA1
Power supply serial number      : AZS1342011F
Model revision number           : F0
Motherboard revision number     : D0
Model number                    : WS-C3750G-24TS-S1U
System serial number            : FOC1344Y1AU
Top assembly part number        : 800-26859-01
Top assembly revision number    : E0
Version ID                      : V03
CLEI Code Number                : CNMWS00ARC
Configuration register is 0xF
Below is the Ios i used in Both Switches
C3750X(12 PORT)  - WS-C3750X-12S : c3750e-universalk9-mz.122-55.SE5.bin
C37504(24PORT)  -  WS-C3750G-12S : c3750-ipservicesk9-mz.122-55.SE5.bin
But My final Doubt  is  still unclear,
1) In c3750X New switch i have only ipbase license(permanent) , ipservices  license is in evaluation. Do i need Ipservices permanent License , in C3750X Stack or with ipbase license itself this stack comibnation  will work?
2) Existing C3750G core stack Doesnt have support license(please see below error) , so will it create any issues or i can add the 3750X Switch with these Stack with 3750x(ipbase license) Alone?
FRLB_BK1_COR3750_01#sh license
Kindly clarify the below doubts
