Stack switch 9200 problem modules C9200-NM-4X
r.bochenek
Community Member
I have a stack of 6 switches 9200, and all of them have 10GB fiber modules (C9200-NM-4X) installed. Unfortunately, they are not working in all switches, and the only difference between these switches is a different H/W version. Could this be the cause?
*1 Active xxxx.xxxx.xxxx 15 V02 Ready
2 Standby xxxx.xxxx.xxxx 14 V01 Ready
3 Member xxxx.xxxx.xxxx 13 V01 Ready
4 Member xxxx.xxxx.xxxx 12 V03 Ready
5 Member xxxx.xxxx.xxxx 11 V03 Ready
6 Member xxxx.xxxx.xxxx 10 V01 Ready
The modules are not working on switches 2, 3, and 6. When I swap the module from, for example, switch 2 to switch 1, everything works fine.
Leo Laohoo
What firmware is the stack running on?
r.bochenek
Community Member
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 17.3.4, RELEASE SOFTWARE (fc3)
I recommend upgrading to 17.9.3 and try again.
r.bochenek
Community Member
ok, it worked.
