STACK WITH WS-C3850-48F-S
Luis Jimenez
hi!!!!
In this week I get 9 switchs WS-C3850-48F-S and I want to know how many switch I can put in stack? how many members can I have in stack?
thanks a lot!!!
Luis Jimenez
forget it I found that the max memebers in stack can be different depends of the IOS version
version 3.3---------------------------9 max members
version 3.2--------------------------4 max members
Luis,
You are correct, 3.3 is the first version to support this and other features such as HSRP and the built in packet capture (this is really cool if you haven't used it - check out this doc by one of my colleagues: Using 3850 Embedded Wireshark (Wired)
Also, you may note that 3.3(1) should be out later this week with a few more bug fixes.
Luke
