stacking 2960S with Core problem
Sheraz.Salim
Below is the config of 2xCore and 4x2960S stacking switch config. the Red colour indiciate the missing vlan and ip default gateway please advise by adding them will fix the stacking problem. as end clinets are unable to get connect to network.
Both CORES are running HSPR
THQ-4507#show run interface vlan 370
Building configuration...
Current configuration : 337 bytes
interface Vlan370
 description C_Hub1_Stack_1
 ip address 10.178.85.4 255.255.255.128
 ip helper-address 10.178.5.152
 ip helper-address 10.178.5.153
 ip helper-address 10.178.1.60
 ip helper-address 10.178.1.61
 no ip redirects
 standby 2 ip 10.178.85.1
 standby 2 priority 101
 standby 2 preempt
 standby 2 track 2 decrement 10
THQ-4507#show run interface vlan 371
Current configuration : 309 bytes
interface Vlan371
 description C_Hub1_Stack_2
 ip address 10.178.85.132 255.255.255.128
 no ip redirects
 standby 3 ip 10.178.85.129
 standby 3 priority 101
 standby 3 preempt
end
SW-CDH-C39-HUB1-C10-1-2-3-4#show spanning-tree active
VLAN0001
  Spanning tree enabled protocol rstp
  Root ID    Priority    8193
             Address     649e.f36a.f880
             Cost        100
             Port        50 (GigabitEthernet1/0/50)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
             Address     5006.ab1b.2b80
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi1/0/50            Root FWD 100       128.50   P2p
Gi2/0/50            Altn BLK 100       128.106  P2p
Gi3/0/50            Altn BLK 200       128.162  P2p
Gi4/0/50            Altn BLK 200       128.218  P2p
W-CDH-C39-HUB1-C10-1-2-3-4#show run interface gigabitEthernet 1/0/50
Current configuration : 188 bytes
interface GigabitEthernet1/0/50
description SX-Fibre-to-HUB1
switchport trunk allowed vlan 1,2,314,370,371,394
switchport mode trunk
mls qos trust dscp
spanning-tree cost 100
end
Hub1-4507#show run interface gigabitEthernet 1/9
Current configuration : 168 bytes
interface GigabitEthernet1/9
description Hub-1_Stack-1_48-G_1
switchport trunk allowed vlan 1,2,200,370,394,395,397,1002-1005,1025-4094   (MISSING 371)
end
W-CDH-C39-HUB1-C10-1-2-3-4#show run interface gigabitEthernet 2/0/50
Current configuration : 174 bytes
interface GigabitEthernet2/0/50
description THQ
mls qos trust dscp
end
THQ-4507#show run interface gigabitEthernet 1/7
Current configuration : 155 bytes
interface GigabitEthernet1/7
description Hub1_Stack1_48G_2
switchport trunk allowed vlan 1,2,200,370,394,395,397,1002-1005   (MISSING 314,371
end
W-CDH-C39-HUB1-C10-1-2-3-4#show run interface gigabitEthernet 3/0/50
Current configuration : 175 bytes
interface GigabitEthernet3/0/50
description HUB1
mls qos trust dscp
spanning-tree cost 200
end
Hub1-4507#show run interface gigabitEthernet 2/9
interface GigabitEthernet2/9
description Hub_1_Stack_2_48-G_1
switchport trunk allowed vlan 1,2,200,371,394,395,397,1002-1005,1025-4094 Missing 370
end
SW-CDH-C39-HUB1-C10-1-2-3-4#show run interface gigabitEthernet 4/0/50
interface GigabitEthernet4/0/50
description THQ
mls qos trust dscp
end
THQ-4507#show run interface gigabitEthernet 1/17
Current configuration : 157 bytes
interface GigabitEthernet1/17
description Hub1_Stack2_48-G_2
switchport trunk allowed vlan 1,2,200,371,394,395,397,1002-1005 Missing 370
end
Interface vlan 370
Description Chorley-Management-VLANs
Ip address 10.178.85.7 255.255.255.128
Ip default-gateway 10.178.85.1
will only giving the command on stack switch (ip default-gateway 10.178.85.1) fix the issue or i re-config the trunk vlans. in spamming tree only one trunk is root rest are blocking so shall i only re-config the root trunk (spanning tree root) or all of them please advise.
please do not forget to rate.
7 Replies 7
Carlos Villagran
Hello
The are some information that needs to be more clear.
Are the end users not even communicating with the access switches (2960s)?? Can you se their MAC addresses?
Are the 4 2960s stacked?
Allowing vlan 370 should be done in every trunk if those links are redundant to the CORE SW, and so if the root had a failure the redundant link would take place to forward vlan 370 frames.
Hello Cavillag,
Yes the 2960s are stack switch running in stack of 4 switches.
the end user are can communicate. i can see the mac addresses.
yes i agree the vlan 370 and 371 are missing on Core trunks.
also i tried to ping from stacking switch to google 8.8.8.8
command i gave ping 8.8.8.8 source vlan 370 is sucessful
but ping 8.8.8.8 source vlan 371 is not working. so i thing the vlan 371 need to be configured on trunk and also ip default gatway needs to be setup.
please share your thoughts
Hello
on the core switch as its performing L3 routing your specify a defaul route and NOT ip default gateways
On the access stacks you apply an management addressing and Default gateway of your mangement vlan created on the core switch - no other default-gateway is required of any other L3 svi applied on the core for any other vlans.
For any host port attached to a vlan in which that vlan is pruned off the switch interconnect trunks - Connection will be negated unless that vlan is allowed to cross the trunks and is also in the vtp database
res
paul
Kind Regards
Paul
Hi Paul
I undersand Core is performing L3 routing. I am more focus on the stacking 2960s. i change the trunk on the stacking and make sure both 2xcore trunk and stacking 2960 are matching same. Now i also set a ip default-gateway on stacking switch.
as this is a production network and we are looking now if this will reslove the problem as some of the devices are unable to get connect. however, once we reload/reboot the windows PC they can connect to the new stacking. I am under the impression is do to some thing with arp caching on windows PC.
Hello
Do you have an addressing issue pertaining to dhcp leasing? - Before the pcs are rebooted can they ping any of the layer 3 addressing on the core switch -
Manually release and renew the addressing on the affected host pcs and see what results you get -
Check the arp table on the hosts also
arp -a
route print
res
Paul
Kind Regards
Paul
Hi Paul.
at the moment things see to be ok. but as its sunday not many people around and we thing it will be fine. however we shall know more on this by monday when staff will come back and connect to the nework.
I mention the same to my technial guy to check and arp-a entries.
I shall get back on monday with any updates.
i thing putting the ip-default gateway command to one of vlan 370 hsrp at 4xstack switch will fix the problem and also the match of trunking.
my tech guy mention they 4xstack switch take around 30 second to go from amber to green. i thing its normal time. i have notice 15 second. but what you thing 30 second amber than going green okay?
Thank all for your support. the network is working good since we match the correct trunk vlan and giving 4xcisco stacks 2060s a ip default-gateway to the core.
thanks you.
