Stacking 3750 and 9200
mlynch_32
I have 4 Cisco 3750 switches, stacked.  I need to add another switch for growth.  Can you add/stack a Cisco 9200 series switch with the Cisco 350 series switches?
Martin L
No, stacking must be within the same model;  besides that I don't think stack-wise cables will fit into ports; you will not be able connect 9200 to 3750 or 2960x.
Regards, ML
**Please Rate All Helpful Responses **
Hello
No stacking between the two models is applicable, However you can connect them together via copper or fibre links.
Kind Regards
Paul
Deepak Kumar
answer is no
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Joseph W. Doherty
As the other posters have noted stacking, at least physical stacking, while creating on logical device (like your existing four unit 3750 stack?) cannot be done between the different series of Catalysts.
It might be possible, however, to manage your 3750 and 9200 as one logical device, but I'm unsure they support this feature.
