Stacking different model switches
Rizwan
Level 4
Level 4
I have Cisco switches of two different models for stacking one Cisco 2960-S and other Cisco 2960-X switch.
Cisco 2960-S is running IOS version 12.2 and Cisco 2960-X is running IOS version 15.0
Currently Cisco 2960-S is working in a stack of three switches and I want to add one more switch of 2960-X model
Should it will work if I upgrade IOS for 2960-S switch?
Just make sure the major and minor numbers match up when stacking different models or you wont get all the features end up with partial stack.
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-software-releases-12-4-mainline/whitepaper_C11-719867.html
Major Version Number Incompatibility Among Switches
Switches with different major Cisco IOS software versions usually have different stack protocol versions. Switches with different major version numbers are incompatible and cannot exist in the same switch stack.
Minor Version Number Incompatibility Among Switches
Switches with the same major version number but with a different minor version number are considered partially compatible. When connected to a switch stack, a partially compatible switch enters version-mismatch (VM) mode and cannot join the stack as a fully functioning member. The software detects the mismatched software and tries to upgrade (or downgrade) the switch in VM mode with the switch stack image or with a tar file image from the switch stack flash memory. The software uses the automatic upgrade (auto-upgrade) and the automatic advise (auto-advise) features. For more information, see the "Understanding Auto-Upgrade and Auto-Advise" section
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swstack.html#wp1223384
Kevin_W
Level 3
Level 3
Hi Rizwan Siddiqi,
on page 5 you can see, that it should be possible to stack both models with each other:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/white_paper_c11-728327.pdf
But like you said, I would bring them on the same IOS level before.
By the way: do all models have the same feature set (Lan-Base)?
