Stackpower switches show in standalone mode
Charlie Jones
I have a stack of 8 3750x switches connected via Stackwise.  In addition, I have these switches configured as two Powerstacks. When I look at the Powerstacks, they are showing as being in power-sharing mode.  When I look at the individual switches, they show as standalone.   Right now, I have 1 switch in each powerstack that has two power supplies, and then the other three have a single power supply. Below is the output for "Show stack-power detail" as well as the Powerstack configurations.
Power Stack           Stack   Stack    Total   Rsvd    Alloc   Unused  Num  Num
Name                  Mode    Topolgy  Pwr(W)  Pwr(W)  Pwr(W)  Pwr(W)  SW   PS
Powerstack_1          SP-PS   Ring     2145    45      570     1530    3    3
Powerstack_2          SP-PS   Ring     2860    60      760     2040    4    4
Powerstack_1-1        SP-PS   Stndaln  1430    520     190     720     1    2
Power stack name: Powerstack_1
    Stack mode: Power sharing
    Stack topology: Ring
    Switch 4:
        Power budget: 700
        Power allocated: 190
        Low port priority value: 20
        High port priority value: 11
        Switch priority value: 2
        Port 1 status: Connected
        Port 2 status: Not connected
        Neighbor on port 1: Switch 3 - e4d3.f15c.6880
        Neighbor on port 2: 0000.0000.0000
    Switch 2:
        Power budget: 700
        Low port priority value: 21
        High port priority value: 12
        Switch priority value: 3
        Port 1 status: Not connected
        Port 2 status: Connected
        Neighbor on port 1: 0000.0000.0000
        Neighbor on port 2: Switch 3 - e4d3.f15c.6880
    Switch 3:
        Power budget: 700
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 4
        Neighbor on port 1: Switch 2 - 6073.5c53.df80
        Neighbor on port 2: Switch 4 - 6073.5c51.dd00
Power stack name: Powerstack_2
    Switch 8:
        Power budget: 700
        Neighbor on port 1: Switch 7 - e4d3.f15e.fd80
        Neighbor on port 2: Switch 5 - e4d3.f12d.2c00
    Switch 6:
        Power budget: 700
        Neighbor on port 1: Switch 5 - e4d3.f12d.2c00
        Neighbor on port 2: Switch 7 - e4d3.f15e.fd80
    Switch 7:
        Power budget: 700
        Neighbor on port 1: Switch 6 - e4d3.f15e.c400
        Neighbor on port 2: Switch 8 - e4d3.f15a.4100
    Switch 5:
        Power budget: 700
        Low port priority value: 19
        High port priority value: 10
        Switch priority value: 1
        Neighbor on port 1: Switch 8 - e4d3.f15a.4100
        Neighbor on port 2: Switch 6 - e4d3.f15e.c400
Power stack name: Powerstack_1-1
    Stack topology: Standalone
    Switch 1:
        Power budget: 910
        Port 1 status: Shut
        Port 2 status: Shut
stack-power stack Powerstack_1
stack-power stack Powerstack_2
stack-power switch 1
stack Powerstack_1
switch mode: standalone
stack-power switch 2
stack Powerstack_1
stack-power switch 3
stack Powerstack_1
stack-power switch 4
stack Powerstack_1
stack-power switch 5
stack Powerstack_2
stack-power switch 6
stack Powerstack_2
stack-power switch 7
stack Powerstack_2
stack-power switch 8
stack Powerstack_2
InayathUlla Sharieff
HI Charlie,
Kindly have a look at the below link:
Managing Catalyst 3750-X Stack Power
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_53_
se/configuration/guide/swstkpwr.html
Inayath
John Capobianco
Cosmetic bug
CSCui21029    3750X Stack no standalone stays in running configureation as standalone
Symptom:
When you are configuring a 3750x stack and initially putting it into a stack ring topology by configuring the following.
Switch(config)#stack-power switch 1
Switch(config-switch-stackpower)#sta
Switch(config-switch-stackpower)#no stan
Switch(config-switch-stackpower)#no standalone
You will see that in the running configuration it shows up as standalone mode
Conditions:
3750X stacks with any license level
Workaround:
none
