Stackwise - 3750s
mike.1979
I have an existing switch stack of 3 cisco 3570s. I need to add a new switch to the stack. Is any configuration on this new switch necessary, or can i just connect it to the stack and it will pick up the config from the current established switches?
Thanks in advance!!
Giuseppe Larosa
Hello Mike,
see the section
Add a Provisioned Switch to a Switch Stack
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml#Add
Hope to help
Giuseppe
Great, thanks Guiseppe.. I just don't want to cause any problems with the configuration of the original switches.
So long as I change the priority on the new switch it should work? I dont need to change any other configuration on the new switch - spanning tree, vtp etc?
Thanks again!!
