Stackwise virtual c9500 interface VSL qsfp Lr4-s: activ member removed
ROGER LE VERGE
Hello
We have a curious bug on a two C9500-48Y4C connected on 4 vsl link with QSFP 100G LR4.No errors on link VSL, no errors on Dad link.All work good for 3 hours or 1 day and sudunly the activ member become and stay removed by redundancy switchover , and the standby member becom activ.
the Ios version is 17.12.4 fc3 .We test 17.9.5 ie .We test the c9500 on the same site :ie. We test the other member activ :ie. A tac Cisco is open (Cisco Poland) No return after trace logs upload. Any one have an idea ?
*Nov 25 2024 16:28:21.341 France: %PLATFORM-6-RF_PROG_SUCCESS: RF state STANDBY HOT
*Nov 26 2024 02:56:29.768 France: %PLATFORM-6-HASTATUS: RP switchover, received chassis event to become active
*Nov 26 2024 02:56:29.827 France: %REDUNDANCY-3-SWITCHOVER: RP switchover (PEER_NOT_PRESENT)
*Nov 26 2024 02:56:29.828 France: %REDUNDANCY-3-SWITCHOVER: RP switchover (PEER_DOWN)
*Nov 26 2024 02:56:29.828 France: %REDUNDANCY-3-SWITCHOVER: RP switchover (PEER_REDUNDANCY_STATE_CHANGE)
2 Accepted Solutions
Response of the Cisco Tac Today , the bug is cause by sfp+ QSFP-100G-LR4-S    not Cisco only compatible .
This can work fine 3 ou 4 days but the errors in the conversation appears without errors on the interfaces
After 4 weeks the stackwise crashed again. The sw001-2 crash witch a boot fail. A second RMA was necessary for the sw001-2. I hope this will be the last. The stack has been working properly for 2 weeks.
9 Replies 9
marce1000
  - You may find this useful : https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9500-series-switches/216537-troubleshoot-svl-on-catalyst-9000-switch.html
 M.
Thanks for the link , i have already control all the link state , all link is up (DAD and VSL), no crc errors .
It seems like Dad decision is bad at a moment , it see vsl link down but they are up ... Nothing in the log events say vsl link are down. The show tech-support stackwise-virtual does'nt give any bad result .
ROGER LE VERGE
sw001-C9500#sh stackwise-virtual link
Stackwise Virtual Link(SVL) Information:
Flags:
Link Status
U-Up D-Down
Protocol Status
S-Suspended P-Pending E-Error T-Timeout R-Ready
Switch SVL Ports Link-Status Protocol-Status
1 1 HundredGigE1/0/51 U R
HundredGigE1/0/52 U R
2 1 HundredGigE2/0/51 U R
HundredGigE2/0/52 U R
sw001-C9500#sh stackwise-virtual dual-active-detection
In dual-active recovery mode: No
Recovery Reload: Enabled
Dual-Active-Detection Configuration:
Switch Dad port Status
1 TwentyFiveGigE1/0/48 up
2 TwentyFiveGigE2/0/48 up
sw001-C9500#sh redun
sw001-C9500#sh redundancy state
my state = 13 -ACTIVE
peer state = 8 -STANDBY HOT
Mode = Duplex
Unit = Primary
Unit ID = 2
Redundancy Mode (Operational) = sso
Redundancy Mode (Configured) = sso
Redundancy State = sso
Maintenance Mode = Disabled
Manual Swact = enabled
Communications = Up
client count = 118
client_notification_TMR = 30000 milliseconds
RF debug mask = 0x0
the bug as today is not resolved no issu from  Cisco Tac .There is no errors on the vsl link en DAD link. The troubleshootting says all is ok.
I try the command vl l2bum optimization today .
The bug is still present, the activ member becom removed., So i configure the switch c9500 with  dual-active recovery-reload-disable may-be we will see more events .
Just formation , the virtual stack work well about 6 weeks but after that randomly the VSL links shut without errors again. The active switch become removed .The Tac Cisco after analysing the trace logs ititiate RMA for sw001-1 .
