StackWisePlus on 3750x
m.glosson
Greetings. I just set up a new 3750x stack of four switches and it's working fine. However, the StackWise is running at 32G, not 64G, which, according to the Data Sheet from Cisco, StackWisePlus is supposed to be 64G when in Full-Duplex mode. Of course, the Configuration Guide says it's only 32 Gb/s. Is there is a divide between the marketing and engineering departments? Perhaps it the whole full-duplex-is-twice-the-speed thing, like each FastEthernet port is capable of 200 Mbps? Check it out:
# show version
<snip>
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24       12.2(55)SE1           C3750E-UNIVERSALK9-M
     2 30    WS-C3750X-24       12.2(55)SE1           C3750E-UNIVERSALK9-M
     3 30    WS-C3750X-24       12.2(55)SE1           C3750E-UNIVERSALK9-M
     4 30    WS-C3750X-24       12.2(55)SE1           C3750E-UNIVERSALK9-M
<snip>
# sh switch stack-ring speed
Stack Ring Speed        : 32G
Stack Ring Configuration: Full
Stack Ring Protocol     : StackWisePlus
What gives?
Thanks.
2 Accepted Solutions
hobbe
Level 7
Level 7
That is true
The stackwise+ consists of two rings.
32 Gb in one ring and 32 in the other = 64 Gb
This is the reason you can release one cable and you will still have 32 Gb in "the ring".
Good luck
That is correct.
it will not show 64 since the ring speed is 32, but you have two rings.
it will when it is correctly connected show
Stack ringspeed :32G
Stack ring configuration : full
stack ring protocol : stackwiseplus
full = both stackrings are complete
half = one stackring is not connected
Good luck
hobbe
Level 7
Level 7
That is true
Good luck
So the result of "show switch stack-ring speed" will never show 64G for the output?
That is correct.
Good luck
