standby default route
josephschung
We have a 3750 stack in site A, by static route, it points all incoming and outgoing traffice to the firewall in site B for security reason.
But, if the inter-site link is down, the default route will not be available. Thus, I think I need another default route, which points to the local site LAN in case the inter-site link is down. Can I give the standby default route a higher distance metric to build up the "HA" of the two default routes? Or is there a better idea?
Thanks!
mrdogantr
    You can use default route with different metric or ip sla.
ip route 0.0.0.0 0.0.0.0 {gw1} 10
ip route 0.0.0.0 0.0.0.0 {gw2} 20
or
ip sla 10
icmp-echo {branch office ip}
timeout 1000
frequency 3
ip sla schedule 10 life forever start-time now
track 10 ip sla 10 reachability
ip route {branch office ip} 255.255.255.255 {gw1}
ip route 0.0.0.0 0.0.0.0 {gw1} track 10
hth
Muammer
Philip Ratzsch
Joseph,
Perhaps http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html#wp1087713 is what you're looking for - look at the 'ip route' section and take a peek at the bit about object tracking.  Essentially, it allow a static route to be installed only if say, a link is up or something along those lines.
Philip Ratzsch
mrdogantr
or
ip sla 10
timeout 1000
frequency 3
hth
Muammer
