Standby Sup-8e Uplink not functional.
msompong1
Hi All,
I have the problem and would like to have some advice , I have Cisco 4510R+E with 2 Sup-8e with SSO mode
and I've noticed that no LED Uplink status for port 1-4 in standby supervisor and the physical link is down now.
Anyone experience with this issue ? And How to fix it ?
below is the show module command found both Sup-8e in slot 5 and 6.
Chassis Type : WS-C4510R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 24 1000BaseX SFP WS-X4724-SFP-E CAT1904L2V1
2 24 1000BaseX SFP WS-X4724-SFP-E CAT1904L2SU
5 8 Sup 8-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP8-E CAT1902L7SZ
6 8 Sup 8-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP8-E CAT1902L7MX
8 24 1000BaseX SFP WS-X4724-SFP-E CAT1923L32D
10 48 10/100/1000BaseT Premium POE E Series WS-X4748-RJ45V+E CAT1903L5VA
Mod Redundancy role Operating mode Redundancy status
5 Active Supervisor SSO Active
6 Standby Supervisor SSO Standby hot
Below is show interface status command
system found the SFP module that connected to the standby Sup
sh int statu | in 6/
Te6/1 notconnect 1 full auto No XCVR
Te6/2 notconnect routed full auto 10GBase-LR
Te6/3 notconnect 1 full auto 10GBase-SR
Te6/4 notconnect 1 full auto No XCVR
Te6/5 inactive 1 full auto No XCVR
Te6/6 inactive 1 full auto No XCVR
Te6/7 inactive 1 full auto No XCVR
Te6/8 inactive 1 full auto No XCVR
Blow is the picture showed that no LED Uplink 1-4 status standby Sup.
7 Replies 7
Leo Laohoo
If I remembered correctly, if the chassis has dual supervisor card, only HALF of the uplink ports will work. The other half are permanently disabled.
So if a line card has 8 ports, then only first four ports will work in each card.
Thank you , Yes you are right !
The first 4 port on each Supervisor card  could be functional.
But for me the first 4 port on my 2nd Supervisor card are not working.
What firmware is the chassis running on?
Thank you.
I'm running on software version below
sh verer
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9-M), Version 03.08.04.E RELEASE SOFTWARE (fc2)
3.8.4 is very old.
Have you tried a different version?
Reza Sharifi
See table-2 in this link:
I have the same sup and same chassis with Portchannels using 5/1, 5/2 and 6/1 and 6/2 with no issues. I have never used all 8. So not sure if that works.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-series-switches/data_sheet_c78-728191.html
msompong1
Hi All,
Thank you for your all advises, Today I've tried with remove the 2nd Supervisor from the chassis and reinstall again now the Uplink status on 2nd Sup is back and the Te-port 6/1 and 6/3 are working.
Regards.
