10-27-2019 02:34 AM - edited 10-27-2019 02:37 AM
Hello everybody,
I am newbies with setting cisco switch.
We bought a Catalyst 2960-x series.
I downloaded Catalyst 2960-X Switch Getting Started Guide but I can't access to Device Manager - Express Setup according to guide.
After following guide, all LED as SYST, STAT, SPEED, MAST and STACK stay green, except the LED of RPS which is off.
I use configuration via Ethernet port 1 (and also on MGM port). And my PC got correct IP... 10.0.2.2 (on Ethernet port1).
When I use internet explorer (on windows 7 and 10) to access https://10.0.0.1, I get pop up window about username and password. I put only cisco as password always according to guide. But I access to Switch Home Page with these topics:
Cisco Systems
Accessing Cisco WS-C2960X-48TS-L "Switch"
Telnet.....
Show interface....
Show diagnostic log...
Monitore the router.....
Show tech-support....
Extended Ping....
Web Console....
and Help Resources.
PS: I attached a screenshot of page which appears
10-27-2019 03:54 AM
10-27-2019 04:21 AM
Thanks for reply.
Here are the complete output to the command "dir".
Output Command base-URL was: /level/15/exec/- Complete URL was:/level/15/exec/-/dir/CR Command was: dir-------------------------------------------------------------------------------- Directory of flash:/ 2 -rwx 1048 Oct 27 2019 07:17:17 +00:00 multiple-fs 3 -rwx 1567 Oct 26 2019 12:20:01 +00:00 express_setup.debug 4 drwx 512 Sep 8 2019 22:58:37 +00:00 c2960x-universalk9-mz.152-4.E8 692 drwx 512 Sep 8 2019 22:58:37 +00:00 dc_profile_dir 122185728 bytes total (91620864 bytes free)--------------------------------------------------------------------------------command completed. --------------------------------------------------------------------------------
PS: I attached a screenshot too
10-27-2019 04:34 AM
10-27-2019 01:52 PM
10-28-2019 01:56 AM
Here the output of the command "dir flash:c2960x-universalk9-mz.152-4.E8" in console
Switch#dir flash:c2960x-universalk9-mz.152-4.E8 Directory of flash:/c2960x-universalk9-mz.152-4.E8/ 7 -rwx 687 Sep 8 2019 22:47:07 +00:00 info 8 drwx 6144 Sep 8 2019 22:47:07 +00:00 html 693 -rwx 24359936 Sep 8 2019 22:49:45 +00:00 c2960x-universalk9-mz.152-4.E8.bin 122185728 bytes total (91611136 bytes free) Switch#
10-28-2019 02:37 AM
10-28-2019 05:17 AM
thanks for trying to help me @Leo Laohoo
After your yesterday last post, I tried myself to find solution because my deadline for beginning test is today.
I found some Catalyst 2960 Switch Cisco IOS command. And I used the setup privileged EXEC command to configure the switch with its initial configuration.
I am currently connected via a network cable switched by Catalyst 2960 that I could not setted via the HTML interface.
So I did my best to setup via PuttY software with serial cable (USB A to mini-USB B).
But I always don't know why express-setup with HTML interface don't work as according in Catalyst 2960-X and 2960-XR Switch Getting Started Guide (French version) .
10-28-2019 05:32 AM - edited 10-28-2019 05:47 AM
Here are my running configuration (the values I modified with PuTTY are in [bold font]):
Output Command base-URL was: /level/15/exec/- Complete URL was:/level/15/exec/-/show/running-config/CR Command was: show running-config Building configuration... Current configuration : 4309 bytes ! ! Last configuration change at 09:47:24 UTC Mon Oct 28 2019 ! NVRAM config last updated at 08:08:11 UTC Mon Oct 28 2019 ! version 15.2 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname [NewSwitchName] ! boot-start-marker boot-end-marker ! logging console emergencies enable secret 5 $1$lErg$y9ayQZKMRguPzjRE3jXFI. enable password [MYPASSWORD1] ! no aaa new-model switch 1 provision ws-c2960x-48ts-l ! ! ! ! ip routing ! ! ! ! ! ! ! ! crypto pki trustpoint TP-self-signed-208430208 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-208430208 revocation-check none rsakeypair TP-self-signed-208430208 ! ! crypto pki certificate chain TP-self-signed-208430802 certificate self-signed 01 30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050505 30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274 69666963 6174652D 32303834 33303230 38301E17 0D313931 30323830 38303546 315A170D 32303031 30313030 30303030 5A303485 2E302C06 03550403 1325494F 532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3230 38343330 32303830 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100 B9197905 7E2474B0 B0A4EF9B E5225263 F4582B82 A6FD7519 497AD3ED 54FD7ADB A0248161 7875952A AF85CA03 B8CB7414 EAE7450B 7CCA4E3D E3D774B2 08C8D8C8 15EB6F01 EB8F2D30 D257ABA6 4BBC7289 1D540306 5DA7CC85 DCC8AD42 39FA3755 3C2184F9 4AEF2AD2 B61BF2D5 EA2F86E6 37D3D2E7 73A6D464 F7004B33 035A0997 02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D 23041830 16801499 96CCDE8D B1AA9078 04699ACA 6B4940EB 0B494D30 1D060355 1D0E0416 04149996 CCDE8DB1 AA907804 699ACA6B 4940EB0B 494D300D 06092A86 4886F70D 01010505 00038181 002BBE55 5C63A7DE AB29BF0A CFD4BD12 61E95C37 C803814B BDB87BFA 7D538542 7542003F A416784D A3518B03 1F5ADB50 0B1F17F6 C4E5DA99 04503E5E DAEFCB33 7E4C9D8C E6E6BFB2 946633D1 5D717DB2 42ABD1B4 62325867 29B35DFB 09FB4CD6 D2B017DB E20AC659 DC1C5552 EED4B351 4790A638 49D1A679 7FE21A94 2B2219D2 2C quit ! spanning-tree mode rapid-pvst spanning-tree extend system-id ! ! ! ! vlan internal allocation policy ascending ! ! ! ! ! ! ! ! ! ! ! ! interface FastEthernet0 ip address [IP address] [subnet mask] no ip route-cache ! interface GigabitEthernet1/0/1 ! interface GigabitEthernet1/0/2 ! interface GigabitEthernet1/0/3 ! interface GigabitEthernet1/0/4 ! interface GigabitEthernet1/0/5 ! interface GigabitEthernet1/0/6 ! interface GigabitEthernet1/0/7 ! interface GigabitEthernet1/0/8 ! interface GigabitEthernet1/0/9 ! interface GigabitEthernet1/0/10 ! interface GigabitEthernet1/0/11 ! interface GigabitEthernet1/0/12 ! interface GigabitEthernet1/0/13 ! interface GigabitEthernet1/0/14 ! interface GigabitEthernet1/0/15 ! interface GigabitEthernet1/0/16 ! interface GigabitEthernet1/0/17 ! interface GigabitEthernet1/0/18 ! interface GigabitEthernet1/0/19 ! interface GigabitEthernet1/0/20 ! interface GigabitEthernet1/0/21 ! interface GigabitEthernet1/0/22 ! interface GigabitEthernet1/0/23 ! interface GigabitEthernet1/0/24 ! interface GigabitEthernet1/0/25 ! interface GigabitEthernet1/0/26 ! interface GigabitEthernet1/0/27 ! interface GigabitEthernet1/0/28 ! interface GigabitEthernet1/0/29 ! interface GigabitEthernet1/0/30 ! interface GigabitEthernet1/0/31 ! interface GigabitEthernet1/0/32 ! interface GigabitEthernet1/0/33 ! interface GigabitEthernet1/0/34 ! interface GigabitEthernet1/0/35 ! interface GigabitEthernet1/0/36 ! interface GigabitEthernet1/0/37 ! interface GigabitEthernet1/0/38 ! interface GigabitEthernet1/0/39 ! interface GigabitEthernet1/0/40 ! interface GigabitEthernet1/0/41 ! interface GigabitEthernet1/0/42 ! interface GigabitEthernet1/0/43 ! interface GigabitEthernet1/0/44 ! interface GigabitEthernet1/0/45 ! interface GigabitEthernet1/0/46 ! interface GigabitEthernet1/0/47 ! interface GigabitEthernet1/0/48 ! interface GigabitEthernet1/0/49 ! interface GigabitEthernet1/0/50 ! interface GigabitEthernet1/0/51 ! interface GigabitEthernet1/0/52 ! interface Vlan1 ip address [IP address] [subnet mask] ! ip default-gateway [IP address] ! ip http server ip http secure-server ! ! ! line con 0 line vty 0 4 password [MYPASSWORD2] login line vty 5 15 password [MYPASSWORD2] login ! ! end command completed.
