Static DHCP entry not assigning to device
I'm having trouble getting a device to pull the correct IP address from DHCP
I configured an extra pool with a client-identifier and that matches what I see in a debug
I had my .70 ip in the excluded range, but still have the issue after removing it
There must be something wrong but I can't think of what else to check
Feb 6 22:33:00.768: DHCPD: DHCPDISCOVER received from client 3ce1.a15d.921c on interface GigabitEthernet0/0.
Feb 6 22:33:02.768: DHCPD: DHCPDISCOVER received from client 3ce1.a15d.921c on interface GigabitEthernet0/0.
Feb 6 22:33:02.768: DHCPD: Sending DHCPOFFER to client 3ce1.a15d.921c (10.200.100.104).
Feb 6 22:33:02.768: DHCPD: creating ARP entry (10.200.100.104, 3ce1.a15d.921c, vrf default).
Feb 6 22:33:02.768: DHCPD: unicasting BOOTREPLY to client 3ce1.a15d.921c (10.200.100.104).
Feb 6 22:33:02.780: DHCPD: DHCPREQUEST received from client 3ce1.a15d.921c.
Feb 6 22:33:02.780: DHCPD: Using hostname 'ring.domain.com.' for dynamic update (from hostname option)
Feb 6 22:33:02.780: DHCPD: Sending DHCPACK to client 3ce1.a15d.921c (10.200.100.104).
Feb 6 22:33:02.780: DHCPD: ARP entry exists (10.200.100.104, 3ce1.a15d.921c).
Feb 6 22:33:02.780: DHCPD: unicasting BOOTREPLY to client 3ce1.a15d.921c (10.200.100.104).
#show ip dhcp binding | inc 1c
10.200.100.70 3ce1.a15d.921c Infinite Manual
10.200.100.135 3ce1.a15d.921c Feb 07 2019 08:14 PM Automatic
ip dhcp pool lan
network 10.200.100.0 255.255.255.0
dns-server 10.200.100.31 10.200.100.10
default-router 10.200.100.10
ip dhcp pool Ring
host 10.200.100.70 255.255.255.0
client-identifier 3ce1.a15d.921c
ip dhcp excluded-address 10.200.100.1 10.200.100.69
ip dhcp excluded-address 10.200.100.71 10.200.100.99
No where in my debug does the device send it with 01
I was able to get this to pull the IP by using "hardware-address" instead of "client-identifier"
johnd2310
Level 8
Level 8
Try the following:
ip dhcp pool Ring
client-identifier 013c.e1a1.5d92.1c
John
**Please rate posts you find helpful**
