05-05-2009 02:41 PM - edited 03-06-2019 05:33 AM
I have a asa 5505 when I set it up for dhcp from my ISP things are great. Now that I have a static IP it dose not work. I have tried creating a static route and I see that it is getting traffic to the DNS server I use but no data is transferred. The doc's are very confusing, I am by no means a network expert. I can not get past that when I enter the static ip information into for the interface (outside vlan2) there is nowhere to add the gateway. I strongly suspect a static route is needed. I have tried to create one still no luck. The documents that came with the router are for there asdm suite I chose inside for the interface then 0.0.0.0 for the ip and netmask and my gateway value from my ISP gave me for the gateway.
Any help is appreciated.
05-05-2009 02:43 PM
John
Not entirely clear what your problem is but your static route should look like
route (outside) 0.0.0.0 0.0.0.0
where
Jon
05-06-2009 05:03 AM
thank you for you replay
I entered this route I can ping any site on the outsdie but can not ping from the inside.
I am wondering if the router just dose not work I can find no reason why I have tryed every route configuration I can think if.
my isp ip is 71.43.97.220 my gateway is 71.43.97.217 mask 255.255.255.248
I enter (outside) 0.0.0.0 0.0.0.0 71.43.97.217
and I can not ping from inside to outside or even see anything on the outside network.
this should work right?
05-06-2009 05:10 AM
John
Just to clarify, you keep referring to the device as a router - do you mean an ASA firewall ?
If you are trying to ping through the ASA from inside to outside then you will need to allow it with either acl's or ICMP inspection, see this link for details -
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml
Jon
05-06-2009 07:17 AM
I can get no trafic from on network to another. The packet trace tool says itis allow when I use it and I use the ping tool form the ASDM.
That being said I will follow the steps in the link. Thank you again for your help.
