static mac entry command
knaik99
if in running config of cisco switch,we are not seeing any command like--
SW1(config)#mac address-table static vlan 1 interface fastEthernet 0/1
 But still we are seeing static entry in show mac address table command
is it done from printers or server side?
Please explain for such static entry
Reza Sharifi
If you have not configured static mac addresses manually and you issue "sh mac address-table" and you see a static mac entry, that is special mac address used by the switch for internal purposes.
