I have found the issue.
The problem was my testing procedure. I simulated the http connection using telnet to http port but i didnt generated any traffic(requests). I repeated the tests using GET requests and the nat session table was replicated almost instant.
I post the degug messages.
The NAT replication trigger is the next segment,request in the tcp session.
Debug messages
Telnet from client
telnet 10.31.73.12 3099 *Nov 7 03:52:17.071: TCBB2701B60 connected to 10.31.73.12.3099GET / HTTP/1.0 GET / HTTP/1.0 GET / HTTP/1.0
New active
Becomes Active at 03:52:32,34
NATGW2# *Nov 7 03:52:32.700: %HSRP-5-STATECHANGE: Ethernet0/2 Grp 100 state Standby -> Active NATGW2# *Nov 7 03:52:32.701: IP-ADDR: ipaddr_table_insert_w_tableid() 10.31.71.254, in global table on Ethernet0/2 NATGW2# *Nov 7 03:52:34.657: %HSRP-5-STATECHANGE: Ethernet0/1 Grp 200 state Standby -> Active
new Active listens for ARP requests for the HSRP IP
*Nov 7 03:52:34.658: IP-ADDR: ipaddr_table_insert_w_tableid() 192.168.153.253, in global table on Ethernet0/1
The nat session is recreated on the new Active .
*Nov 7 03:52:34.745: NAT: API parameters passed: src_addr:10.31.71.3, src_port: 0 dest_addr:10.31.73.12, dest_port:0, proto:6 if_input:Ethernet0/2 pak:B072F0A8 get_translated:1 *Nov 7 03:52:34.745: ipnat_api_translated_address_and_port_common, out->in want IL,OL *Nov 7 03:52:34.745: NAT: API Translated-Info(1): (src-addr:10.31.71.3, src-por t:0) (dest-addr:192.168.153.12, dest-port:0)
Thanks for helping.
エイドリアン
