Static NAT problem on 1841 router
Dimafo123
Visitor
Hi all.
I have a Cisco 1841 router at home with version 12.4(13r)T advanced ip services.
The setup is extremely simple:
1) PPPOE dialer to my service provider over ADSL
2) Nat overload on the dialer interface.
3) 2 Vlans one for home network (wired) and one for wireless both vlans are connected through interface vlans respectively.
My problem is when I configure static NAT to map RDP or any other protocol to inside hosts this doesn`t work.
ip nat source static tcp 192.168.20.3 2222 interface Dialer1 2222
ip nat source static tcp 192.168.20.3 3389 xx.xx.xx.xx 3389 extendable
ip nat inside source list 20 interface Dialer1 overload
P.S
When I open wireshark and sniff the traffic on home computer which is the one I`m trying to reach I can`t see any traffic.
and While performing nat debuging I am also not able to see traffic going to that port (for example 3389)
Ok, with your interface-config one problem is visible:
On the interface you use the "legacy" NAT, but the global NAT is the more modern NVI-style.
Change your NAT from
to
ip nat inside source static tcp 192.168.20.3 3389 xx.xx.xx.xx 3389 extendable
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
7 Replies 7
That's not your IOS-version. The IOS-version is printed in "show version" above that.
Regarding your problem: Have you allowed the traffic in your external ACL?
Hi Karsten.
Thanks for quick reply
The IOS is c1841-advipservicesk9-mz.124-25b.bin
and basically I don`t have an ACL on the dialer interface if thats what you are asking:
interface Dialer1
ip address negotiated
ip verify unicast source reachable-via rx allow-default 100
no ip proxy-arp
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username xxxxx
password 7 xxxxxxx
end
Here is the nat overload configuration together with it`s ACL:
< ip nat inside source list 20 interface Dialer1 overload >
< access-list 20 permit 192.168.0.0 0.0.255.255 >
thanks again.
I suppose this is not for Dialer 1 but for the other ISP connection ?
Regards.
Alain
Hi Alain.
I have only one ISP conenction which I connect to over PPOE at dialer1.
The config line above is when I tried doing a configuration for IP address instead of interface, so basically xxxxxx is the
address I have got from my ISP via dialer 1.
to
Thank you so much!!
works like a charm
good catch
Regards.
Alain.
