static route fails
homer_mgx
Hi all,
Im new here and want do practise the dealing with cisco switches.
I have a test switch here with this config:
The port 1 is connected with a firewall. Between firewall and switch i have a transfernetwork.
Switchport1: 192.168.0.1 and Firewallport 192.168.0.2
And we have a defaultroute
ip default-gateway 192.168.0.2
ip route 0.0.0.0 0.0.0.0. 192.168.0.2
So all clients take the defaultroute.
Now i have a second firewall connected with Port 2
I have created a VLAN 10 and add the ip 10.10.20.254 to the VLAN 10
Applied VLAN 10 to the port 2
The second firewall which is connected with Port 2 is configured with the ip: 10.10.20.1
So i have a transfernetwork between Port2 and the second firewall
after that i done this:
enable
conf t
ip route 15.240.60.238 255.255.255.255 10.10.20.1
exit
Now if i run traceroute to 15.240.60.38 the first hop should be the 10.10.20.1
But it is still 192.168.0.2
Hmmm
any idea what im doing wrong?
if i run show ip route
the new rout is not listed
if i run show running-conf
i see this:
hope you can help me
Thanks all
cadet alain
Can you post sh ip int br output as well as sh int status output
Alain
qing2220871119
Hi:
   you set
   ip route 15.240.60.238 255.255.255.255 10.10.20.1.the mask is /32 .
   but you try traceroute to 15.240.60.38,so it still use your default route.
   so the new route list is not be used.
   if you ip address is 15.240.60.38 255.255.255.0,you can ip route 15.240.60.0 255.255.255.0 10.10.20.1
Cena
FranckL
What is the model of your switch?
Because maybe you try to do routing on a L2 switch?
