Storm command model 2960G
alexisbonilla84
Frequent Visitor
Frequent Visitor
Is there any way to apply this command on these switch models?
Or can you suggest a comment that does not generate a loop on the ports?
This need for port connect to hosts
Spanning tree portfast
Spanning tree bpdu guard enable
do you know how to use this command on an interface?
Hi @alexisbonilla84
 By storm do you mean "storm control" ? If so, you can use the command
nterface interface-id
storm-control unicast level 87 65
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swtrafc.html#71262
