Storm Control issue
madmat_c2
I have a network that is now carrying a lot of multicast traffic in a single VLAN (CCTV)
We have done a lot of configuration in the network to limit the effects of the multicast traffic, but have just started to have some strange issues.
Basically I have a port that used to have multicast storm control on but it has been removed, but it still gets tripped by storm control randomly at times, this is causing issues of traffic being blocked and dropping of the HSRP between our two main switch stacks.
Any ideas on this?
The enviorment that this is happening in is a Cisco c3750e stack of 4 switches, running IOS 12.2(50)SE3.
Matt
8 Replies 8
Hello Matthew,
Would you be so kind to let us know how did you verify the mcast traffic got limited by storm-control?
Thank you
Best regards,
Dmitry Skotnikov
-- Best regards, Dmitry Skotnikov
Hi I see the following in the logs on the switch
STORM_CONTROL-3-FILTERED: A Multicast storm detected on Gi2/0/24. A packet filter action has been applied on the interface.
Hello Matthew,
Would you be so kind to gather the following outputs:
show version
show running-config interfaces gi2/0/24
show interfaces gi2/0/24 counters storm-control
Thank you
Best regards,
Dmitry Skotnikov
Hi Dmitry
I am unable to run "show interfaces gi2/0/24 counters storm-control" it says it is an invalid command, the others are below.
Show run int gi2/0/24:
interface GigabitEthernet2/0/24
description link to switch-1 Vlan45 only
switchport access vlan 45
switchport trunk allowed vlan 45
switchport mode trunk
priority-queue out
mls qos trust dscp
no snmp trap link-status
channel-group 6 mode on
spanning-tree portfast
show ver
#show ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(50)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 22-Jul-09 05:35 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02400000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750E-HBOOT-M) Version 12.2(35r)SE1, RELEASE SOFTWARE (fc2)
PSEWLB044AS3750E-1 uptime is 19 weeks, 3 days, 24 minutes
System restarted at 09:18:15 NZST Sat Apr 27 2013
System image file is "flash:/c3750e-universalk9-mz.122-50.SE3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipservices
License Type: Permanent
Next reload license Level: ipservices
cisco WS-C3750E-24TD (PowerPC405) processor (revision F0) with 262144K bytes of memory.
Processor board ID FDO1219V1G7
Last reset from power-on
35 Virtual Ethernet interfaces
1 FastEthernet interface
112 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1D:70:46:E6:00
Motherboard assembly number : 73-10313-11
Motherboard serial number : FDO12180KGM
Model revision number : F0
Motherboard revision number : A0
Model number : WS-C3750E-24TD-E
Daughterboard assembly number : 800-28590-01
Daughterboard serial number : FDO12170ATP
System serial number : FDO1219V1G7
Top Assembly Part Number : 800-27546-03
Top Assembly Revision Number : A0
Version ID : V02
CLEI Code Number : COMSE00ARA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
1 28 WS-C3750G-24TS-1U 12.2(50)SE3 C3750-IPSERVICESK9-M
2 28 WS-C3750G-24TS-1U 12.2(50)SE3 C3750-IPSERVICESK9-M
* 3 30 WS-C3750E-24TD 12.2(50)SE3 C3750E-UNIVERSALK9-M
4 30 WS-C3750E-24TD 12.2(50)SE3 C3750E-UNIVERSALK9-M
Switch 01
Switch Uptime : 19 weeks, 3 days, 25 minutes
Base ethernet MAC Address : 00:17:5A:E1:04:00
Motherboard assembly number : 73-9637-08
Power supply part number : 341-0098-01
Motherboard serial number : FOC1011349E
Power supply serial number : DCA1007038G
Model revision number : C0
Model number : WS-C3750G-24TS-E1U
System serial number : FOC1012Y09S
SFP Module assembly part number : 73-7757-03
SFP Module revision number : A0
SFP Module serial number : CAT10081DWL
Top assembly part number : 800-26349-02
Top assembly revision number : B0
Version ID : V02
CLEI Code Number : CNMWZ00ARB
Switch 02
Base ethernet MAC Address : 00:17:5A:E0:C4:80
Motherboard serial number : FOC10113RDW
Power supply serial number : DCA100703B4
System serial number : FOC1012Y084
SFP Module serial number : CAT10070Z81
Version ID : V02
Switch 04
Switch Uptime : 19 weeks, 3 days, 24 minutes
Base ethernet MAC Address : 9C:AF:CA:2F:4B:80
Motherboard assembly number : 73-11177-13
Motherboard serial number : FDO13481411
Model revision number : G0
Model number : WS-C3750E-24TD-S
Daughterboard assembly number : 800-29737-01#
Daughterboard serial number : FDO134712HE
System serial number : FDO1348R1SX
Top assembly part number : 800-28924-01#
Top assembly revision number : C0
Version ID : V03
CLEI Code Number : COMSE00ARB
License Level : ipbase
License Type : Permanent
Next reboot licensing Level : ipbase
Configuration register is 0xF
Hello Matthew,
I can see the port is a part of GEC, would you be so kind to capture the following:
show etherchannel 6 summary
show running-config int po6
show storm-control po6 multicast
show storm-control gi2/0/24 multicast
Thank you
Best regards,
Dmitry Skotnikov
Hi Dmitry
show etherchannel 6 summary:
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
6 Po6(SU) - Gi2/0/24(P) Gi3/0/4(P)
show running-config int po6:
interface Port-channel6
show storm-control po6 multicast:
Invalid input detected^
#show storm-control gi2/0/24 multicast
Interface Filter State Upper Lower Current
Hello Matthew,
That's unclear where the messages come from, without storm-control configured. How often do you receive the messages on the box and are there another boxes with similar behavior?
Best regards,
Dmitry Skotnikov
Hi Dmitry,
Thus my problem, we do not have it configured on this port, we do rescive the messages randomly, when it does happen, it normaly happens a few times in a row. We do have storm control configured on other ports and it is working as expected. This is the only port that we get this on that does not have storm control configured.
Matt
