STP between switches
SJ K
Level 5
Level 5
Switch 1 <-> Switch 2 <-> Switch 3
1) Does Switch 2 forward STP bpdu packets from Switch 3 to Switch 1 and vice versa in STP communication ?
2) Does Switch 2 forward bpdu of another STP type which is different from the current STP type the switch is running
e.g. Switch 2 is in MSTP - does it forward STP bpdu packets from Switch 3 to Switch 1 running in PVST ?
Mark Elsen
 -  In general it doesn't work that way : STP is 'organized' per Vlan and or configured-vlans following protocols long being in place before 'the dawn of mankind' :-)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
". . . STP is 'organized' per Vlan and or configured-vlans . . ."
Just a note, that would be if using one of Cisco's per-vlan STPs, other vendor ("standard") STP implementations often are not per VLAN, further if using the later MST variant, you select what VLANs are assigned per MST region.
Cristian Matei
    1. A switch running let's say RSTP, will NEVER forward a BPDU between its trunks or access-ports; STP is hop-by-hop; each switch receives BPDU's, takes actions on them, and based on the end resulting port states and roles, it will generate its own BPDUs out on specific links; so generate, not flood/forward received BPDUs
   2. If a switch does NOT run STP, it's disabled, when it receives a BPDU, which is use a specific multicast destination address, it should forward it, treat it like a "data packet", flood it out as being multicast; based on some testing i performed, it's not always the case, and it kinda makes sense; why would you want to have a legacy switch in legacy access design, where without STP there is no switching as there will be loops.
   3. A switch running MSTP, it will detect if directly connected switches run MSTP (if so, it will send out MSTP BPDUs), or STP/RSTP (in which case it will send out STP/RSTP BPDUs).
Cristian Matei.
