STP disabling edge ports
MPerrino17
Hello All,
I have a simple network of 3 switches in a triangle, and each switch as 1 PC connected.  How can I prevent STP from disabling the edge ports?  The only way I can prevent this is to plug the PC's to Switch's first and then connect the switches together.  Any ideas?
Mark Malone
Add spanning tree portfast and spanning tree bpduguard to the switch port interface where the pcs are connected
Hi Mark, Thanks for your reply.  I tried that and still nothing.  Here is the show running-config for that port.
interface FastEthernet0/3
spanning-tree portfast
spanning-tree bpduguard enable
The port is not even listed in the show spanning-tree command
If spanning-tree is shutting down ports, there should be an entry in the log to indicate the reason.  PC's have only one interface?
Spanning-tree portfast just allows the PC to connect to the network earlier rather than wait the learning time of ~ 40 seconds.  the bpduguard will shut down the port  if it sees BPDU packets, which a PC shouldn't be sending (unless you're running something odd on the PC?).
