STP for wireless backup
Haris P
Level 7
Level 7
Dears ,
We have two wireless bridges configured between 2 buildings and we are using Cisco 2960 switch in both sides .
Can we use STP to make the one link as failover to other one . We have one primary link which is much capable and we want to make the second link as backup
Haris
andrew.prince
Level 11
Level 11
Configure a higher STP port cost on the "backup" link - this will make STP use the best = lower ports costs as the primary link.
HTH>
Can you provide some sample config ??
Haris
You can either change a sepcific VLAN cost or the whole port cost:-
Interface x/x
spanning-tree vlan 1 cost 65535 = VLAN cost
or
spanning-tree cost 65535 = port cost
HTH>
