STP Priority
daniel.bowen
Level 5
Level 5
Hi All,
I have two core switches running numerous VLANs, and several access switches connected resiliently into both switches. These access layer switches run the same VLANs and I want to load balance them across both core switches. In other words, I want each core switch to be the root bridge for half of the total VLANs.
My question is, how do I configure STP to do this?
Can I simply adjust the switch priority on a per VLAN basis on the switch I want to have as the root bridge?
Many thanks in advance,
Dan
ankbhasi
Hi Dan,
You can run this command on your core 1
spanning-tree vlan root primary
and same command you can run on core 2 for same vlans to make it a secondary root bridge for those vlans
spanning-tree vlan root secondary
Use reverse for other set of vlans on 2nd switch to make second core as root and same command for those vlans on core 1 to make 1st core as secondary root bridge.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/spantree.html#wp1037815
Ankur
*Pls rate all helpfull post
krishnakomiti
Level 2
Level 2
Please check the below link, I think will be useful for you.
http://cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00800ae96a.shtml
Krishna.
If you have numerous VLANs, running PVST may result in increased CPU utilization. You can go for MST in that case.
http://www.cisco.com/warp/public/473/147.html
Nagendra
